by Zoemarsden
When charging I have a water drop mark and an exclamation mark on my s8. Help?
7 REPLIES 7
Re: When charging I have a water drop mark and an exclamation mark on my s8. Hel
You mean this:
It means GPS/location services cannot pinpoint your location.
Good morning @Zoemarsden.
Is @Northerner image what you see on the device?
If so you can turn this off by displaying all apps and select Settings > Location > Turn off.
Let us know if you need anything further 🙂
by Zoemarsden
No
This is what i see
Sent from Yahoo Mail on Android
Hello @Zoemarsden.
Sorry no image is showing.
Is this only when the device is on charge?
Thanks 🙂
@Zoemarsden wrote:
No
This is what i see
@Zoemarsden is it that shape? is listed here:
Thanks,
by Zoemarsden
Yes when i charge it there is a water droplet at the bottom of the screen and the top has a triangle with an exclammation mark on
Thanks @Zoemarsden.
Has there been any damage done to the device at all?
Also how long has this been happening?
Thanks 🙂
