by Dazza78
Whatsapp pictures not sending
Huawei p20 not sending WhatsApp pictures unless on WiFi. Any ideas?
Solution
Re: Whatsapp pictures not sending
Hi @Dazza78
Try logging into your MyEE app then - Settings - Content Lock - change this to off. Then restart your device.
It should now work.
Thanks,
Solution
Hi @Dazza78
It should now work.
Thanks,
Hi @Dazza78
Welcome to the community.
@Northerner's tip should do the trick.
Let us know how you get on.
