by Calc1
What does it mean when it says data change
by Ace Contributor
Re: What does it mean when it says data change
It normally shows data change when you change your tariff.
by Calc1
But I've not changed my tarrif I upgraded in June last year
by Ace Contributor
is the amount of data still the same ?when does it say the your data changed ?
Hi @Calc1
Welcome to the community. 🙂
Where does it say data change?
Is it in your My EE account?
Or do you mean data "charge"?
