by 2766 Investigator
Weird network problem...
I have a Samsung S3 Mini on T-Mobile PAYG. When connected to a wifi network everything works fine. Over the last few days when using the phone via my T-Mobile PAYG SIM I can send and receive text messages but none of the apps - pre-installed or installed by myself via the Play Store - connect/work.
I have not changed any network settings. I have credit on the phone. The network is showing as either ‘H’ or ‘3G’ and the yellow and green arrows are flashing as normal. I have signal strength ‘bars’ showing. I've done a factory reset but still no joy. Any help appreciated.
Re: Weird network problem...
Good Afternoon @2766
Thanks for posting on the community.
Have you deleted one of the apps and reinstalled this at all?
Do calls work ok?
Thanks 🙂
Thanks for your reply.
Yes, I've deleted and reinstalled various apps and prior to deleting I deleted their cache, data and uninstalled updates.
After the factory reset, a couple of apps on reinstallation said that they were not compatible with my device even though they were installed and working fine before the problem started.
Yes, I can make and receive calls.
Hello @2766
Thanks for coming back to me.
Can you access the internet?
Is your software up to date on the device?
Thanks 🙂
Software update is up to date.
Can access internet when on wireless. When trying to access via T-Mobile network it says 'couldn't establish a secure connection'.
Thanks @2766
We will need to look into this for you.
If you can give us a call our customer service team can get this investigated for you.
Let me know how you get on 🙂
