by Chez64 Investigator
Volume using bluetooth
When I use my Nokia 3 on the bluetooth in my car, I struggle to hear the incoming call.  I have turned up the volume using the radio volume control but it's still not loud enough.  I have used previous phones in the car but never had this problem before.  Has anyone else had the same problem, and is there a solution?  Thanks
8 REPLIES 8
Re: Volume using bluetooth
Hello @Chez64
Thanks for posting on the community.
Can you hear calls when you're not connected to the Bluetooth in the car?
Has this worked in the past for you?
@Chez64  Have you tried turning up the volume on the phone ?
Yes I've tried that. Someone has suggested I unpair the phone and start
again so when it stops raining I'll try that! Thanks for your suggestion.
Let us know how you get on @Chez64
Thanks, Leanne 🙂
Hi Leanne
Yes, I can hear the phone in the car when the Bluetooth is not connected. Someone suggested I unpair it and then re-pair it, which I have done a couple of times, but there has been no improvement. Do you have any other suggestions?
Chez64
Sent from Mail for Windows 10
Hi @Chez64,
Have you tried contacting the manufacturer of your car to see if it's a known issue?
Do you have another a bluetooth device you could test your phone with? This should confirm if the fault is with the phone or your car.
Hi @James_B
I have just paired it in my husband's car and it was fine, so I think I am going to go back to the shop that supplied the phone and see if they can help me.
Cheryl
No problem @Chez64
Please keep us updated.
