by OxfordDJ007
New Member
Voicemail set up issues
I've just recorded a personal voicemail greeting and saved it, but upon phoning my phone from a landline to test, it isn't going through to the voicemail and rings and rings and rings?
I may be missing out on work due to this! Help anyone please!
by Profile closed
Not applicable
Solution
Re: Voicemail set up issues
@OxfordDJ007 try sending a free text to 150 with the phrase VM ON as that should enable voicemail diverts on your account.
You should then get a text back telling you to reboot your handset to complete the set-up.
by Profile closed
Not applicable
Solution
Afternoon @OxfordDJ007
Has the great advice from @Profile closed worked for you?
Thanks, Leanne 🙂
