by HazelW
New Member
Voicemail remote access
Hi. I wish to change my recorded voicemail message without using my phone to call my voicemail service.
I'm abroad at the moment and don't want to make any roaming calls from my phone. I could ring from another phone, though, if I can find out how to access my voicemail and record a new message remotely.
Thanks if anyone can help.
Solution
Re: Voicemail remote access
@HazelW  To set this up outside of the UK you will need to call customer services so a pin can be set up to access your voicemail.  You can then call your voicemail from any phone by putting in the PIN number.
Solution
