Highlighted
by Investigator
Voicemail error
When I try to check my voicemail it asks me to leave a message so I can't actually check my messages. What am I doing wrong?
Highlighted
by Ace Contributor
Solution
Re: Voicemail error
@elviscoolcat if you dial 222 does it allow you to access your voicemail ?
6 REPLIES 6
Highlighted
by Ace Contributor
Re: Voicemail error
Hi @elviscoolcat
What are you doing in order to check your voicemail? It may sound like a daft question, but something's going wrong so it may be useful to know what you're doing.
I've half an idea what might be happening, but also what phone are you using?
Highlighted
by Ace Contributor
Solution
Re: Voicemail error
Highlighted
by Investigator
Re: Voicemail error
Success - dialing 222 got me to my voicemail, thank you 🙂
Highlighted
by Investigator
Re: Voicemail error
I was hard pressing number 1, or clicking on the icon. It appears I need to dial 222. I have an S20 ultra. Thanks for trying to help me 🙂
Highlighted
Re: Voicemail error
Thanks for letting us know you got this working, @elviscoolcat.
Hopefully other users with the same problem can see this and do the same as you 🙂
Jon
Highlighted
by Ace Contributor
Re: Voicemail error
Great news, I'm glad @David has helped..
Pressing and holding your "1" key should still work - you might find that switching your voicemail off by texting VM OFF to 150, then switching it back on using VM ON to 150, and then rebooting your phone - should restore your speed-dial.
