by Helen14
New Member
Voicemail Recording
I have a Moto G4, can someone please tell me if it's possible to record your own voicemail message, and if it is, how do I do it ?
Thank you very much
Helen
by Profile closed
Not applicable
Solution
Re: Voicemail Recording
Hello @Helen14 it is possible to record your own voice greeting yes. Just call 222 from your EE phone to access your voicemail service then use option 2 from the main menu for greetings. 🙂
by Profile closed
Not applicable
Solution
