by Johnparma1
Vo))
How do I get this off the top of my screen
by Stupot81 Contributor
Solution
Re: Vo))
Its Voice over lte = HD calling over 4g
You cant clear it unless you switch it off in phone settings.
This also enables you to use the internet and us the internet simutainusly
Solution
Re: Vo))
