by noeljim
Usage
how have I managed to use 292 mb of 300 mb within 3 days
Re: Usage
Have you:
  • Restricted background apps under Mobile Data?
  • Only do Software Updates over WiFi under My Device?
EE Employee
Re: Usage
Hello @noeljim
Just to add to the questions  @XRaySpeX asked, have a look at our How much data sticky post to help understand how your data is used.
Hope this helps!
Thanks - Karen. ;smileyhappy:
by hawkerpaul Contributor
Re: Usage
Just go into Settings>Data Usage
Scroll down to see what apps have used data
This will give you an idea on the hungry ones
