by Doctor_T Established Contributor
Upgraded to PIXEL 3 from NEXUS 5 - NAT failed via hotspot
Hello Team
I am at wits end trying to solve this issue for last couple of months visiting EE store, talking to Sony and people who think they know something :p, you guys are my last resort.
I normally, use hotspot to connect to PS4 which was working completely fine with my Nexus 5 (please see picture).
MVIMG_20181115_131338.jpgPS 4 setting with NEXUS 5
However, greed of data made me upgrade to PIXEL 3, and now my hotspot does not work with PS4 - error - NAT FAILED. (please see next picture)
IMG_20181115_150608 (1).jpgPS 4 with PIXEL 3
However, if i use this new sim that i got in the old phone, i.e Nexus 5 works fine! I have tried changing APN EE internet settings and selected IPV4 but has not helped. Used Google DNS servers on PS 4 no luck. Not sure what else to do? Its a mission to change sims everytime.
I hope you gamers out there can understand my frustration.
Please any advice/encouragement or even better a solution would be most welcome.
Thank you for taking your time to read my rant.
Regards
Solution
Re: Upgraded to PIXEL 3 from NEXUS 5 - NAT failed via hotspot
All sorted. What you need to do is set up an apn. Use ipv4 as soon protocol and use name as ee secure and the rest settings copy from your original APN. Finally ! Taken 7 months!!
36 REPLIES 36
Were both the Nexus and the Pixel both running on EE SIMs?
Hello, thanks for such a prompt reply. Yes the Nexus was initially running on an ee SIM and the pixel is now running on a new SIM which I got post upgrade. This new sim works on the old Nexus too and gives no NAT issues unlike the pixel.
Hi @Doctor_T
Are you able to connect other devices to your Nexus 5 hotspot and use the internet successfully?
by Ace Contributor
Try changing your hotspot name on your Pixel so it's not the same as the nexus5, and set it up again on the PS4, and make sure it's set to 2.4Ghz for it.
Affirmative Chris. I can connect to the internet. I can connect to the PS4 and use the internet too but cannot game online as NAT status fail.
Hi Chistery
Changed name of hotspot. Still no success 😞15471188150114410408515834294593.jpg
The Nexus is quite old & may not support IPv6 whereas the Pixel probably does. I think the answer may lay in that area. Can the Pixel be forced to use IPv4 only?
Thank you for reply. No I cannot edit the EE settings but I set up a separate VPN mimicking the settings and changed to IPv 4. Still no luck. Please see below. These settings let me connect to the internet and connect the PS4 to the internet via hotspot but still NAT failed.  Screenshot_20190110-141254.png
Hi @Doctor_T,
Have you tried asking for help over in the PlayStation Community?
I wonder if the issue can be resolved by changing some settings on the PS4?
Hi James
Yes I have thanks. They say issue is worth your service provider as the hotspot via ee sim works with Nexus ( NAT type 2). Switching it to pixel it doesn't using the same ee SIM. ( NAT failed).
As seen above, it connects to internet. The NaT issue needs to be addressed by your service provider.
Thank you 😞
Good Morning @Doctor_T.
Had anyone on the Playstation Community had similar issues and told you how they got it fixed?
Have you tried contacting our technical support team?
Jon
Hi Jon
People with similar issues said they got their ISP to sort it out.
I have contacted the technical support team who after evaluating the issue suggested I get a broadband connection :p.
It's not what I was hoping for but I understand they want to encourage customers to buy their products.
Thanks for getting back to me @Doctor_T.
Would broadband be an option for you? 🙂
It definitely sounds like something needs to be changed in the settings of the phone.
Hopefully someone with a similar experience can help with this!
Jon
Hi Jon ,
I concur , it's a phone setting issue as the same SIM works on Nexus 5. Just the pixel 3 is being annoying. Ideas are welcome 🙂
I know @Doctor_T!
I'd definitely recommend keeping an eye on this community and also the PlayStation Community to speak to other users.
Let us know if you find anything further 🙂
Jon
Nothing to report unfortunately 😞
by Skilled Contributor
Skilled Contributor
What settings is your pixel 3 handing out as noticed in the screenshots your ip is same but dns and gateways are different.
15473408185417736046261277125994.jpgCurrent settings with pixel 3 on PS4
15473409004618743099758034557440.jpgPlease note NAT failed
Hi Mirdragon
Many thanks for your time and assistance, please see settings as requested .Hope you have a good weekend .
@mirdragon: They would be.
  • The IP addy is the local IP of the PS4.
  • The Default Gateway & DNS are the local IP of the phone being hotspotted to.
Recent solutions
