by Shep1
Upgrade
I have received my upgraded phone and sim today which I ordered via ee website. I have set it up but it says emergency calls only. Do I need to do something else or will it just swap over itself. If so how long should it take and will I keep my same number. Thanks
Re: Upgrade
It could take up to 24 hours and if your old sim goes dead then you know it's done.
EE Employee
Re: Upgrade
Hi @Shep1 and welcome to the Community.
Please do follow the advice given by @Northerner but if you are still not connected after 24hours please pop over to our SIM Activation guide.
Many thanks,
Lee
