Highlighted
by Investigator
Upgrade query
If I take a new phone with my upgrade and continue whatever payments are due, can I give the phone to my wife? She's sim only on EE. Thanks.
Highlighted
by Investigator
Solution
Re: Upgrade query
No problem, but thanks again for your reply 👍🏻
⁣Get BlueMail for Android ​
6 REPLIES 6
Highlighted
by Brilliant Contributor
Re: Upgrade query
In theory the device belongs to EE for the first 6 months but if you keep up with the payments there shouldn't be a problem.
BrendonH (Android Expert) Samsung Galaxy S10+ (Android 10/One UI 2.1)
Highlighted
by Investigator
Re: Upgrade query
Thanks for that... I was hoping to get the new Mate 30 Pro but not if it won't support Google apps. My wife has a Pixel 2xl so I thought I'd give the upgrade to her as I have a 2nd contract which has an upgrade due in February next year. Appreciate your prompt reply, thank you👍🏻
Highlighted
Re: Upgrade query
The Mate 30 pro will support google apps.
Existing Huawei is fine.
The sanctions only effect new phones being released
Highlighted
by Investigator
Re: Upgrade query
I have the Mate 20 Pro which is fine but the upcoming Mate 30 Pro is covered by Trumps ban and for the time being won't support Google apps. Thanks.
Highlighted
Re: Upgrade query
Ah sorry yes. Got confused which was the current version  🤦‍♂️
Highlighted
by Investigator
Solution
Re: Upgrade query
