Highlighted
Unlocked phone
I have a unlocked phone can I put my ee monthly contract sim card into the phone
Highlighted
by Ace Contributor
Solution
Re: Unlocked phone
Hi @david8541
Yes 😀
It's possible some features like VoLTE or VoWiFI may not work or need some changes but you can put your EE SIM into any unlocked phone you like.
Any questions, let us know!
Highlighted
by Ace Contributor
Solution
Re: Unlocked phone
Hi @david8541
Yes 😀
