by Alberto1000
Unable to call & texts receiving message "no signal found for mobile networks"
For 24 hours now I have been unable to make calls and send texts receiving message "no signal found for mobile networks".  I have switched phone on and off, checked date/ time settings are correct and appear to be registered with EE in mobile network settings.  Any suggestions how to get back up and running?
by Brilliant Contributor
Re: Unable to call & texts receiving message "no signal found for mobil
Hello @Alberto1000,
Welcome to the community,
Have you taken the SIM card out of your phone, given it a wipe, then put it back in and re-booted the phone to see if it works?
Are you able to try the SIM card in another phone to see if it works? It could be that the SIM card or the phone have developed a fault.
