Highlighted
by Investigator
Txt from EE?
Txt from 1167 saying was from EE and generally offering more data etc, and then a link to go on, is this EE or a scam
Highlighted
by Ace Contributor
Solution
Re: Txt from EE?
Yes, that's a genuine EE text.
Among other things, it refers you to ee.co.uk which scammers would tend not to.
Highlighted
by Ace Contributor
Re: Txt from EE?
Hi @Amatthews
What did the text say, exactly? Don't go on the link unless you're sure but what was the link?
If it's from EE, it would tend to include something along the lines of "or call 150" - but this isn't guaranteed.
Highlighted
by Investigator
Re: Txt from EE?
Hi Adrian EE here. Our phones are crucial at the moment and we've got
communication covered. Our monthly recurring unlimited data add-on gives
you data with no limits:video call,use social media and stream content as
much as you need. And as a valued customer, until 23rd May your special
price is just £20 extra per month. Cancel any time. Standard price £25p/m.
Reply YES to this message and we'll do the rest. Term
and fair use policy apply. http://discover. ee.co.uk/J4e495A1
Text STOP to 1221to opt out of marketing....
The number that this text came from was 1167.,,,,thanks
Highlighted
by Ace Contributor
Solution
Re: Txt from EE?
Highlighted
by Investigator
Re: Txt from EE?
Thank you very much, very helpful👍
