by robertf
Turn off samsung j3(6) call status tones
How do you turn off the call status tones on a samsung J3 as its driving me mad.
There are no options in  call settings to do so.
cheers
EE Employee
Re: Turn off samsung j3(6) call status tones
Hi @robertf and welcome to the community.
Please can I get you to follow the bellow to see if that helps:
  • Open the Phone app.
  • Tap on the Menu key > Call settings.
  • Tap on Call Alerts
  • Scroll to the "Call status tones" section and uncheck the following options:
  • Call connect tone.
  • Minute minder.
  • Call end tone.
Many thanks,
Lee
by robertf
Lee
Thanks for the response.
On the J3 there is no menu key in the phone app, there is a "More" menu item that takes you to settings. But the call setting options doesnt give you "Call Alerts"
You can also hold down the back button (as the menu button) but it also open teh "more" menu items with same results as above.
The options are Show my caller id, call forwarding, call barring, call waiting and fixed dial numbers
Cheers
Rob
EE Employee
Hi @robertf
It may be worth popping over to the Samsung support pages to see if they can assist.
Many thanks,
Lee
