Highlighted
New Member
Turn off parental lock
How do I turn parental lock off?
Highlighted
by Ace Contributor
Solution
Re: Turn off parental lock
Hi, @Lbag88  'log in to My EE ' and ' My EE Mobile' and then 'Manage Device'. You'll see a page with your devices listed, select 'Manage your device' under the device you'd like to set the control. On the 'Data content controls' page, select the 'Moderate' or 'Strict' option to set controls.
Highlighted
by Ace Contributor
Solution
