by Jordanrh Investigator
Transferring data from S5 with broken screen to S7?
I am trying to transfer the contents of my Samsung S5 to my new S7. However, although the S5 switches on the screen is broken so I am unable to use it.
12 REPLIES 12
Re: Transferring data from S5 with broken screen to S7?
Hi @Jordanrh
Welcome to community and thanks for posting 🙂
Be careful with the screen, you don't want to end up with glass in your hand.
I had a look around for you and I think this should help you with how to transfer your data.
Hope you manage to do it.
Keep us posted.
Richard
Thank you for your reply. Unfortunately this doesn't work as it asks me to click allow/trust on the old phone (S5) but there is no screen for me to do this?
No problem @Jordanrh
I am going to tag in @Northerner and @BrendonH to see if they can possibly lend some Android expertise in this area please.
Thank you
Richard
What content are you trying to transfer?
Most info/contacts will be stored on your Google account (if you allowed it) or photos on your memory card (if you had one).
Thank you for stepping in @Northerner
Richard
Hi Northener,
I need my contacts, calendar and notepad and some important screenshots. I have my photos from my sd card but I didnt have my google account on. The data is saved to the device which is switched on and has sound but no screen?
@Jordanrh wrote:
Hi Northener,
Your Google account is on by default unless you disabled it. Your notes will be backed up on Samsung (if you used Samsung notes) have you logged onto your Samsung account?
Did you have any security (password, patten etc) if not turn on your phone and connect it to Samsung kies and you should be able to backup.
If you
EE Employee
Good advice @Northerner
Hopefully this will help @Jordanrh
Cheers
Lee
Thank you for your reply. I turned the google backup off and I don't have a Samsung account?
EE Employee
Hi @Jordanrh
Please do try the Samsung Kies solution which has been offered.
Many thanks,
Lee
Hi Lee,
I have tried Samsung Kies but it doesn't appear to be able to connect to my phone, I must have really damaged it.
Thanks everyone for your ideas. It is much appreciated.
by Brilliant Contributor
You must have a Samsung account. I'm sure it doesn't let you by pass this.
