by Skilled Contributor
Skilled Contributor
Transfer data/apps from p20 pro to s10+ phone clone or smart switch?
Which is the best way to transfer all my stuff from huawei to s10+. Used smart switch but never used phone clone - advise please?
by Brilliant Contributor
Re: Transfer data/apps from p20 pro to s10+ phone clone or smart switch?
The S10 will come with a little device which you plug into each phone.
This will transfer everything over.
Hi @djslapper
Smart switch, then again if you back everything up on your Google account then you shouldn't need to transfer much.
by garetbe Established Contributor
I’ve used Smartswitch in the past and it’s been more than adequate.
