by Mazdaman
New Member
Texting stop pack will £5 credit be available if required in an emergency
As I will only use the 'pay as you go' phone for an emergency in the car I have added a £5 credit, turned it off and sent the above text to EE, I was led to believe that credit will still be there if I need it, in a month or 6 months. Is this correct?
I have no other use for carrying a mobile phone.
by Profile closed
Not applicable
Solution
Re: Texting stop pack will £5 credit be available if required in an emergency
Hello @Mazdaman the £5 credit will stay there yes but you need to make a call or text at least once every 3months to keep the SIM active & keep the credit. Here is a link containing more information on the EE PAYG hibernation process. :):
https://community.ee.co.uk/t5/Pay-as-you-go/Pay-as-you-go-Hibernation-Information-on-EE/td-p/392179
by Profile closed
Not applicable
Solution
