by BroganH20 Investigator
Text not sending
I'm trying to send a text that is '62/2' characters long, when sending shorter texts the text goes through with no problem. However the 62 character text keeps saying it has failed to send.
16 REPLIES 16
Re: Text not sending
EE Employee
Welcome to the Community @BroganH20
Is the text to one particular number or does it happen when trying to send any shorter texts?
What phone are you using?
Thanks - Karen. Smiley Happy
What do you mean by '62/2'? Is it the 2nd part of a long SMS of about 222 chars long?
Some phones convert long SMS to MMS for which you will be charged. If you're on PAYG & you don't have sufficient credit, the MMS will not be sent.
Galaxy s6. Perfectly fine to send shorter texts. I've never had this problem before
EE Employee
Hi @BroganH20
Is the text to one particular number?
Does the text contain any sort of image or emoji?
No images or emojis used, and is a problem with more than 1 number.
EE Employee
Hi @BroganH20
Is the content of the message always the same?
It's strange that it's converting it to 2 texts if it's only 62 characters!
Yes, tried to forward the text on to a friend to see if it would work.
Definitely more than 62 characters, but on the side of the screen it says 62/2.
@Karen_C: It's not converting it to 2 texts & it's longer than 160 chars. "nn/2" is what you see when you spill over into a 2nd part after going over 160 chars.
@BroganH20: Are you on PAYG? If so, do you have credit of at least 40p? If not, that's why!
EE Employee
Hi @BroganH20
The 62/2 means it's across two texts - one will be 160 characters and the second part is 62 characters.
Is it a text that you've written or content that you're trying to forward?
@Karen_C: I've already said that twice!
We're going round in circles at the moment. I wrote the text myself.  It is not working to any number. Short texts are working to every number. Do you have a solution to this?
I might have if you were to answer my Qs:
Contract with unlimited texts
Yes I realise this. I'm not stupid
Ah, OK, then it's not that then.
Look in your messaging app Settings & see if it's preventing MMS being sent.
