by meggabecca66-00
Still cant send pictures messages even with setting it up via EE
Hi, I have a LG K8 but have to list is as LG K350n, followed the instructions via EE - Installed, but said would received of things to do within 5 mins, did not receive anything and still can not send picture messages, with or without data turned on or off. Any suggestions please. Thanks
Re: Still cant send pictures messages even with setting it up via EE
@meggabecca66-00   Try sending a MMS to yourself.   Just to add MMS are chargeable and are not part of your tariff.
by meggabecca66-00
Thanks for reply tried sending to hubby but nope no joy, not worried about cost dont sent them that often, but I have 6gb data and I dont really use data, not used it within last 2 weeks lol, would rather have the ability to send pics then all this data.
Hello there @meggabecca66-00
Welcome to the community, thanks for joining 🙂
Could you try and send the MMS settings again to your number.
If this does not work, give us a call on 150 we will be able to get this looked into for you.
Let us know how you get on 🙂
