by triggerhappy21
Sony X Compact - no Nougat
I have an EE sim only deal, and used an unlocked Sony X Compact handset.
When would I expect to get the Nougat update? I have a friend with a Z5 Compact that has been updated for months, but mine still seems to not be available.
Thanks.
Re: Sony X Compact - no Nougat
If its unlocked and unbranded then any update will come from Sony direct not EE.
Thanks,
