by Juveriyyah Investigator
Sim card error
My phone a LG G3 S has been showing up as no sim. I have tried taking the sin out and no luck. I also put on airplane mode. What can i do?
6 REPLIES 6
by Profile closed
Not applicable
Re: Sim card error
The first thing I'd try is get yourself a new SIM card by calling into your nearest EE store and they will switch everything over for you.
If you are still having issues, it's probably a handset fault which will then need a repair.
Re: Sim card error
How long have you owned the handset and did you get it from EE?
Re: Sim card error
I have had it for 2 years now. I bought a sin only plan in november as my phone was in a good condition
Re: Sim card error
Hi @Juveriyyah,
Welcome to the EE Community.
Do you have a different phone you could test the SIM card in?
Re: Sim card error
No unfortunately i have a very old htc but i dont think it will take in my new sim as i use a smaller sim in this phone.
Re: Sim card error
No problem @Juveriyyah
I would follow @Profile closed's great advice and pop in to your nearest EE store to try out a replacement SIM card.
