by Alfiesmam Investigator
Phone suddenly stopped failing and receiving calls. Please help x
11 REPLIES 11
Re: Samsung
It could be one of a hundred reasons.
Can you provide a bit more information.
  • Did you get your phone from EE?
  • Are you on EE PAYG or pay monthly contract?
  • Are you in credit on your account?
Re: Samsung
Phone is from E E. In credit and able to text and go online
Sent from my Samsung Galaxy smartphone.
EE Employee
Re: Samsung
Hi and welcome to the community @Alfiesmam
Please do popping the phone off and back on to see if that helps.
Many thanks,
Lee
Re: Samsung
Have tried that. Have full signal and everything. Can't even take incoming call
Re: Samsung
Hello @Alfiesmam
Thanks for coming back to us.
Are you able to try the SIM in another phone at all?
This will help us to see if this is the phone or SIM causing this.
Thanks, Leanne.
Re: Samsung
The phone is a sealed unit. I would have to take the entire back off???
Re: Samsung
Hi @Alfiesmam
The SIM card is removable from the device.
What device are you using?
Thanks, Leanne.
Re: Samsung
Samsung galaxy edge 6. However i also don't think I have a compatible
devise to check it in
Re: Samsung
Thanks @Alfiesmam.
If you can pop into an EE retail store they will remove the SIM tray and try this in another device for you.
If not give us a call and we will be able to help you with this 🙂
Thanks, Leanne 🙂
Re: Samsung
Thank you. Will give this a go x
Re: Samsung
No problem @Alfiesmam
Let me know how you get on 🙂
