by djasja Contributor
Samsung s8 screen fault
All of a sudden a green light has appeared down my s8 screen...anyone have any ideas 15210616680491688090583.jpg
8 REPLIES 8
Re: Samsung s8 screen fault
Hi @djasja
Your screen or motherboard is damaged. Have you dropped the phone or allowed it to get excessively wet?
Your phone should still be under warranty, so you can either contact Samsung direct here or take your phone into EE and they will send it off for assessment.
I
Hi thanks for replying it's only 4 weeks old and in a protective case and never been dropped or for wet.
This is my first Samsung as always had Apple so very unhappy.
Not sure how I can get it sorted as I am out the country on work for the next 2 months!
I will try contact EE
Hi @djasja
Where did you get the phone from and what was the date?
Did you speak to our technical support team?
I upgraded online. I will ring support later today when I am back from work.
by Expert Contributor
Expert Contributor
I notice there's no edge screen handle in your photo. It might mean that somehow the handle has been set to maximum height and green colour. So worth checking the settings.
Of course, it's also possible the fault covers up the edge screen, but still worth spending a minute checking.
How do I check that? Been a iPhone guy for 10 years and just got a Samsung. Like you say worth checking
Hi there @djasja
If you can go into Settings > Search for Screen Mode > Then Screen Edge Colour
Adjust the colour slider to the preferred setting, then select Apply and OK.
Let us know how you get on.
Expert Contributor
On Oreo its
Settings>Display>Edge Screen>Edge Panels>Three Dots (In top right)>Edge Panel Handle
to check the size and transparency.
