Highlighted
Samsung s20 aux lead
Anybody know if there is a lead that I can plug from my s20 into my cars aux lead I bought a extension which goes from Jack pin to type c but it says its un supported an now I'm fed up cause I can't listen to my music In  the car plz some1 help me or suggest a lead that supports mt phone tia
Highlighted
Solution
Re: Samsung s20 aux lead
Amazon?
Highlighted
Hi @Powlez
Get a 3.5mm Bluetooth adapter for you car, then stream over Bluetooth from your S20. No wires needed.
Highlighted
Where would I get 1 from an ive never seen them
Highlighted
Solution
Amazon?
