by Chattabob Investigator
Samsung s10 screen wake up
Can anyone help...
I have multiple issues with my samsung s10
Screen radomly wakes up every 20 seconds
Camera films then stops 20 seconds in
Gaming pauses itself same period
Above and beyond deleting apps or factory resetting what can I do?
Gesture and lift to wake ect have been turned off
Solution
Re: Samsung s10 screen wake up
I ended up completely wiping my phone and it did the trick... for three weeks and now it's started again 😞 I've installed nothing new on my phone so it can't be that. How do I go about getting a replacement as sending it away is only going to last the same time bere it starts again
9 REPLIES 9
Hi @Chattabob
Do you have a case/screen protector?
I would try factory resetting your device.
Thanks, I've done a soft reset but it did not fix the issue. What will i lose if I do a factory reset?
Good Morning @Chattabob
You will loose everything when factory resetting your device. If you do this I would recommend ensuring you have everything backed up.
Please keep us updated with your progress,
Katie 🙂
Thanks,
I've done a factory reset and nothing has changed, whats my next step?
Thanks for trying the factory reset @Chattabob
Please get in touch so our Tech Gurus can look into this in more detail for you.
They'll be happy to help. 🙂
Solution
Hi @Chattabob.
Thanks for getting back to us.
At this point I'd recommend getting in touch with our Tech Gurus.
They will be able to run through the next steps of troubleshooting with you and let you know what the best options are.
Jon
By pure chance I've found out what was waking my screen up. I have the ring app that goes with the floodlight camera. My girlfriend set it up on her phone and after logging in her screen started waking up. We've both logged out and our phones no longer wake up
Thanks for the update @Chattabob 🙂
