by soni13782 Investigator
Samsung note 8 wifi calling
Good Morning
Need urgent help. I have just received my samsung note 8 from EE. This morning I am in hospital. I do not get any network at all so I was using iphone's wifi calling.
How do i activate wifi calling in Note 8?? I have checked in setting>connetion> more connection setting> there is not wifi calling option.
Please help how do i activate otherwise I am without phone.
Thank you,
by Brilliant Contributor
Solution
Re: Samsung Note 8 wifi calling set up
Open the phone app.
Three dots are the top right.
Settings
Scroll to the bottom.
That's where you will find the Wi-Fi calling setting.
Good Morning
Thank you,
Solution
Open the phone app.
Settings
by Expert Contributor
Expert Contributor
@soni13782 it's with in call settings.
Open dial pad then 3 dots at top right scroll down and it's at the bottom of list 👍
Re: Samsung note 8 wifi calling
Hi @soni13782
I see @BrendonH's answer has been marked as a solution.
Are you all sorted?
Chris 🙂
