by Inflictor
New Member
Samsung note 10 plus signal issues
Hi
ive just received the new note 10 plus 5g
my signal has dropped dramatically and using a sat nav the signal is intermittent
any ideas on what to do
ive tried resetting network settings but it’s still the same
thanks
Re: Samsung note 10 plus signal issues
Good Morning @Inflictor
Is this happening in specific areas? you can check for known problems by using our Network Status Checker.
Are you connected to 5G or 4G when this happens?
Speak soon,
Katie 🙂
by iandrob01 Investigator
I have the same problem. It is a known issue and Samsung are trying to sort it apparently. It happens when the satnav switches between 5g and 4g areas as you travel. The workaround is to switch to "up to 4g" in the "settings/connections/mobile networks/network mode" menu.
This should have been tested properly before launch.
I certainly don't want another recall after the 7.
by Hughzy
New Member
MeRe: Samsung note 10 plus signal issues
I'm having the same issues. My iPhone Xs and Huawei p30 pro have full bars but my note is on 1 or 2.
A quick search on this and it seems this is a known fault with the Note 10 and + and seems to be a hardware fault.
Also the battery life is shocking
Last note I had was a 7 and we know what happened there. Massively regretting getting this phone.
Re: MeRe: Samsung note 10 plus signal issues
Hi @Hughzy.
Welcome to the community.
I'd recommend getting in touch with our Tech Care team about this, they will be able to run through troubleshooting with you and try to get to the bottom of the problems you're having.
Jon
