by ams2k0104
Samsung galaxy s8 cutting out when playing audio
Whether it is playing through the speakers, headphones, casting to a device, using spotify or playing podcasts my phone keeps cutting out when playing music or podcasts. I've tried a number of suggested "fixes" including preventing USB tethering in the developer options and clearing the cache in the boot options. Can anyone offer any further advice or suggestions on how I go about fixing this? It's a new phone too I only got it in March.
Solution
Re: Samsung galaxy s8 cutting out when playing audio
Hi @ams2k0104
Does this happen when your phone enters sleep mode?
Settings - device care battery - three lines. Check which apps are in the sleep option. You could also try disabling the app sleep options.
This isn't a hardware issue it's a Samsung Android issue.
Solution
Hi @ams2k0104
Good Evening @ams2k0104
Thanks for coming here.
Can you try the suggestions from @Northerner and let us know if this works for you?
Hope to hear back from you soon.
Leanne 🙂
by ams2k0104
That's it!
Thanks very much.
@ams2k0104
Happy I could help!
