by Sbish Investigator
Samsung galaxy s7, screen won't rotate, gyroscope sensor not working any advice?
6 REPLIES 6
Re: Samsung galaxy s7, screen won't rotate, gyroscope sensor not working any adv
@Sbish   If you have not disable this feature on the device yourself then it'll be best if you contact Samsung as you get a two year warranty with that device.
Try factory resetting your phone first.
Also make sure it's active on the quick shortcuts.
Good morning @Sbish
Thanks for visiting the community for support 🙂
Please let us know if the help @Chris_B and @Northerner have given to you has helped you.
Richard
Chris, Thanks for this i will give EE a call
I have tried reset,  checked another way by doing *#0*# and the sensor isnt working at all im presuming it broken, i will call EE
EE Employee
Good Morning @Sbish
Did you try a full backup and factory reset?
If so and it still wasn't working you can either contact us or see if you have a Samsung repair centre close to you.
Let us know how it goes!
Thanks - Karen. Smiley Happy
Recent solutions
