by Kate1978
Samsung galaxy s7 edge data
On the data usage on my Samsung it says 2gb allowance but my plan is actually 7gb. Can I change it?
Solution
Re: Samsung galaxy s7 edge data
The 2GB is the notification limit which us set by default so when you have used 2GB the phone will alert you, it's not any limit. If you click on it you can change it to whatever you want.
Solution
Just move the sliders up. It's your setting not EE's.
Hi @Kate1978
Thanks for coming to community 🙂
I hope the great answers @XRaySpeX and @Northerner have given to you have helped to answer your questions?
Thank you
Richard
