by itsmeagain
Samsung galaxy j5 will not charge up when connected.Connection feels loose
The phone was charging well until about  2 weeks ago.
Now more and more problems.Slightest touch will stop phone charging and needs readjusting on a table or flat surface. Charging was no problem until then. Gettting worse
by Ace Contributor
Re: Samsung galaxy j5 will not charge up when connected.Connection feels loose
@itsmeagain
It look like its charging port have problem.
Did you try with an other charger?
Do you have insurance for your phone?
If you have ask them they might help you regarding this.
Many Thanks
by itsmeagain
Thanks Tahir.
I will take it to EE  shop tomorrow.
Have you tried a different charging cable to see if that fits better?
