by mazzledazzle Investigator
Samsung galaxy a5 cannot connect to wifi network
Hello, Hope someone can help. My Samsung did an update on Saturday and ever since, I've had issues connecting to my home broadband. At first it just was intermittent connection but now, my phone wont even search for any wifi networks. The slide button wont turn on at all.
8 REPLIES 8
Re: Samsung galaxy a5 cannot connect to wifi network
Hi @mazzledazzle
Try forgetting the wifi network on your device, and then connecting again. If not back up and factory reset your device.
Thanks,
EE Employee
Hi @mazzledazzle and welcome to the community.
After following the wonderful advice of @Northerner in regards to the forgetting and connecting back to the WiFi please can I get you to try the following.
Clearing Cache:
  • Turn off the phone
  • Press and hold “Power”, “Volume Up”, and “Home” at the same time
  • When the “Samsung” logo appears, release “Power
  • At the “Android” logo, release all hardware buttons and after a moment you should see the “Android system recovery” menu
  • From here, press “Volume down” repeatedly to highlight “Wipe cache partition
  • Press “Power” to select the highlighted option
  • After the cache is cleared, “Reboot system now” should be highlighted
  • Press “Power
Then try connecting, let us know how you get on.
Many thanks,
Lee
Hi, thanks for the suggestion. I have tried this but to no avail unfortunately. The bluetooth also doesn't work which I forgot to mention. Any other suggestions?
Sounds like both WiFi & Blootooth are both broken on your phone.
Hi thank you for your advice although it wont allow me to get as far as forgetting the network as the wifi toggle wont even turn on. The bluetooth also wont turn on.
That's why it looks broken.
Yes it would seem that way wouldnt it. The next option will be going into store to see if they can fix it or send it off or something.
Hello there @mazzledazzle
Thanks for coming back to us.
If you do pop into an EE retail store they will be able to help you.
If not, see our ways to book a repair help page.
Leanne 🙂
