by liamscor Contributor
Samsung S8 Plus VoLTE
Hello,
I just joined ee on sim only deal. I have the Samsung Galaxy S8 Plus bought direct from samsung with the oxm csc. I notice on the ee website is says 4g calling will only work if bought from ee. However on my phone, it now shows volte next to 4g in the top bar. I also now have an option to turn it on. Just wondering if ee have done something to allow it to work.
Regards,
Liam
Solution
Re: Samsung S8 Plus VoLTE
Yes, that's the latest firmware. Both VoLTE & WiFi Calling are available on that.
11 REPLIES 11
What are your firmware versions given by dialling *#1234# ? They're all "OXM"; need more.
Both VoLTE & VoWiFi are available on S8s with the Oreo v8.0.0 update.
Hi XRaySpex,
Thank-you for your response. I have inserted a screenshot of the firmware.
Regards,
Liam
Solution
Thanks for confirming.
Thanks! You're welcome :)! Glad I could be of assistance.
by Ollie2222 Contributor
If I'm understanding correctly then 4G and wifi calling will now work with handsets bought directly from Samsung or a tird party such as Carphone Warehouse providing they have the latest firmware.
If this is the case then do you happen to know if this also applies to the S9 and the S9+?
by Brilliant Contributor
It is handset specific. The S8 only started to work close to the S9 coming out.
My guess is that they want you to buy the new S9 with them.
Maybe @Christopher_G could clarify?
Thanks for the quick reply and info,
The general info on the web seems to be that the S8 and S9 need to be purchased directly from EE but I've come across a couple of references to people saying the latest firmware allowed stock versions to work but there seems to be a lot of misinformation around and I don't want to make an expensive mistake.
Hi @Ollie2222,
EE WiFi Calling is supported on S9's not purchased from EE, but please check when buying a phone from a non-EE retailer whether or not it supports WiFi Calling, as we cannot guarantee phones purchased from third parties will support the feature.
EE 4G Calling is only supported on S9's purchased from EE at this time.
Hope this helps. Smiley Happy
Thanks for the reply and info, that matches with what I've generally read.
No problem @Ollie2222 Smiley Happy
