by Bluestake Contributor
Samsung S10+ and 4G and 5G
Could someone tell me if the S10+ which EE are offering at the moment is only 4G or is it also 5G compatable when we get it. Would like to know before upgrading to it.
by Ace Contributor
Solution
Re: Samsung S10+ and 4G and 5G
Hi @Bluestake
The S10 available at the moment is only compatible with 4G the 5G variant will be available later this year.
by Ace Contributor
Solution
Hi @Bluestake
by Ace Contributor
Well thanks for that information Dave. Unless ee are going to give a free upgrade when they put out the 5G, might as well wait for now and down grade my plan meaning I have finished my 24 month contract.
by Ace Contributor
@Bluestake your free to move to sim only then upgrade once 5G launches.
