by searsy
Samsung J3
My new Samsung J3 has frozen can't turn it off or on ??
by Ace Contributor
Solution
Re: Samsung J3
Hi, @searsy
Please soft reset your device .
You can do this by keep press and hold the Power and Volume down buttons for 12 seconds or until the device power cycles.
I hope it can fix your issue.
by Ace Contributor
Solution
Re: Samsung J3
Hi, @searsy
by searsy
Re: Samsung J3
Very helpful thank you
Re: Samsung J3
Hi @searsy
Welcome to the community. 🙂
Did @tahirmian's advice fix this for you?
by searsy
Re: Samsung J3
Sure did 👍
Re: Samsung J3
Awesome. 🙂
Feel free to come back to the community if you have any problems or questions in future, @searsy.
Chris 🙂
