by feefee2071 Investigator
Samsung 7 chargers
Does anyone know why samsung chargers dont last long i have went through about 5 in the last year they just stop working x
EE Employee
Solution
Re: Samsung 7 chargers
Hi and welcome to the Community @feefee2071
It may be worth speaking directly with Samsung on this one.
Many thanks,
Lee
Having only owned Samsung equipment I can say I have never had any issues with the charger on any of the phones or tablets.
If you have gone through 5 in the last year then you are either very unlucky or you are treating them poorly.
If you want a solid replacement search out the Anker ones on Amazon.
Thanks,
I have only owned Samsung equipment myself and treat them properly and only has happened with the s7 thanks for your input .
Sent from Yahoo Mail on Android
by Jamie__S13 Established Contributor
If you mean the cables themselves, mine tore at the end within under 6 months, and an identical one I got with a Samsung tablet is on the verge of tearing too...
The cables are fine the just stop working
EE Employee
Solution
Many thanks,
Lee
