by Welshmaverick Investigator
S8 wireless tethering
Hi
I have a Galaxy S8 and I have tethered it to my laptop via wireless connection. The two devices are connected but the laptop says "connected but no internet connection".
I have the same problem with my S8 and amazon firestick too.
Regards
Kev
10 REPLIES 10
Re: S8 wireless tethering
Have you entered the correct tethering password on your devices?
Yes done that as they are connected to each other. Just have no internet connection.
Cheers
Hi @Welshmaverick
Can your laptop connect to any other wireless connections?
Also, can your phone tether to other devices?
Look forward to hearing from you.
Hi
Laptop can connect fine via router at home. Phone will connect to laptop and firestick but both say "connected but no internet connection" (phone has full4g signal)
Regards
Kev
Thanks for trying that @Welshmaverick.
I recommend speaking to our technical support team so that they can run some tests with you.
Let me know how you get on.
Cheers
@Welshmaverick
Try going into tethering/wifi hotspot settings and changing the password, then connecting again.
Are you receiving a 4G signal on your phone?
Thanks,
done that and yes got 4g on phone and phone will connect to internet
Cheers
So did that get it working, @Welshmaverick?
no still not working!!! Smiley Frustrated
OK, thanks @Welshmaverick.
I recommend speaking to our technical support team.
They'll do their best to help.
