by neils31 Established Contributor
S7 tempered Glass screen protector?
Anyone have a tempered glass protector for the S7 that is any good and fits with a spigen rugged armour case ?
It does not have to completely cover the screen just enough incase i drop the phone on an uneven surface and whilst its in my pocket 🙂
thanks in advance.
by Brilliant Contributor
Solution
Re: S7 tempered Glass screen protector?
Try This one
This one from Amazon suit your needs?
11 REPLIES 11
EE Employee
Hi @neils31 and welcome to the Community.
I wonder if @Northerner or @Damienw1 can advise on the accessories as they use the S7 I do believe.
Many thanks,
Lee
I cannot say tbh as my S7 Edge doesn't have any case or screen cover.
Hi @neils31,
We have a Zagg screen protector available in our accessories store that may suit your needs.
Hope this helps.
Hi James,
thanks for that, but it seems its for the S7 edge
Sorry @neils31 - try this one.
Solution
Try This one
@James_B
Although yours is a good one but it's out of stock. Do you know when it'll be back in case @neils31 goes for that one?
@BrendonH - cheers just what I am looking for.
Hi @BrendonH,
I don't have a date at the moment but accessories from most suppliers are restocked pretty quickly.
Thanks for sharing the other link.
@BrendonH well got the protector today, it doesnt adhere to the screen on both side of the phone about 4mm - so ive sent it back for a refund ....
Sorry for the issue there.
It was same make as your case so thought it would be perfect.
I'll dig round some more when I am at home.
