by JA1701
S7 sound problem
My S7 has begun to mute randomly. It does it on apps games and video. Considering taking it back to the store
by Brilliant Contributor
Re: S7 sound problem
Have you changed any settings?
Try clearing cache or factory restore.
It will still be under warranty so can be fixed using this.
