by R050588 Investigator
S7 loudspeaker problems
After updating my samsung s7 to nougat my loudspeaker will not work after 5 seconds it plays for the first 5 seconds then will not
I have tried factory reset and deleting cache
Re: S7 loudspeaker problems
Does this happen with all media you play and apps?
Apps is fine but all media and loudspeaker calls is affected
Hi @R050588,
Thanks for joining the EE Community. Smiley Happy
I would get in touch with customer service so our technical team can help.
If you follow the link above you can even chat with our technical team online.
Hope this helps.
by neils31 Established Contributor
@James_B wrote:
Hi @R050588,
Hope this helps.
EE are now supporting Nougat on the S7 ?
Hi @neils31
Thanks for posting 🙂
@James_B has gone home for the evening, so I wanted to pick this up.
I think James offered help based on the speaker issue.
Hopefully the technical team helped the customer.
Cheers
Richard
