by ynot68 Established Contributor
S7 edge nougat upgrade
Any idea when we will get android 7 for the s7 edge. Is it worth flashing btu and losing voLTE but keepinh wifi calling, or is it better to wait for the upgrade.
Re: S7 edge nougat upgrade
You won't know until EE start force-feeding it. EE never pre-announce OS updates.
by Profile closed
Not applicable
I'm waiting for the EVR version as I've read some have gone back to Marshmallow because BTU Nougat 7.0 doesn't support VoLTE.
It's going to be a while before EE release it going on previous updates but I guess it comes down to whether you want VoLTE (when it's working 😉 )
