by neils31 Established Contributor
S7 Edge firmware update
I received a firmware update yesterday, anyone know what it was?
Im still on 6.0.1 Marshmallow and have the following versions:-
G935FXXU1BPLJ/
G935FEVR1BPK5/
G935FXXU1BPL1
6 REPLIES 6
EE Employee
Re: S7 Edge firmware update
Hi @neils31
The versions you have is for the release that was uploaded on or around the 25th of December.
I am trying to find out exactly what's in the change log, soon as I do I will let you know.
Many thanks,
Lee
It's bug fixes and brings your firmware up to date with the latest security updates from Google /Samsung.
EE Employee
Thank you @Northerner
I have found the Samsung changelog code, but no way of finding what the changes are 🙂
Many thanks,
Lee
by red_snow Established Contributor
@Northerner It does indeed, however a changelog will or should detail those bug fixes vs. a generic "it fixes bugs" statement which you could say is true for most updates!
by isneddersi
When is the release of Nougat 7.0?
by ChrisP4GEE Investigator
If the press is to be believed the 17th January is the roll out date in Europe. 🙂
