by Staceycw89
S6 nougat
when will the Samsung s6 getting the nougat update? Be nice to get a straight answer instead of your phone will notify you? Is it even on its way yet? Have any other s6 on ee had the update yet? It's very frustrating.
by Ace Contributor
Re: S6 nougat
@Staceycw89
You have answer in your own question and no one can give you time and date about this,
Many Thanks
