by Marc1
S6 edge is not working properly
My s6 edge touch pad keeps freezing and not working when I tap it and also a pink vertical line keeps appearing on my screen. Can anyone help me
by Profile closed
Not applicable
Re: S6 edge is not working properly
Hello @marc6 if a back up and restore does not fix the issue then you probably have a faulty device/screen and would have to get this looked into under warranty/insurance if possible. 🙂
