by brasske Investigator
Roaming
Hello. I am abroad the UK (in ES zone) and I cannot use my phone (maybe my Roaming isn't turn on?). Please help me.
EE Employee
Re: Roaming
Hi @brasske and welcome to the community.
So I can try and help, please may I get you to perform a manual network search and choose a network other than what you are on, if in Spain please do try Movistar
Please, also can I get you to try and dial a friend or family member using the format of 00447********* and try using data.
Did this work?
Many thanks,
Lee
Re: Roaming
I am in Lithuania.
EE Employee
Re: Roaming
Hi @brasske
My apologies I thought you were referring ES as Espana (Spain).
If you are unable to find a network after a manual search it does sound like you are not set up for roaming.
Our customer services team will be able to set it up for you.
I recommend logging into your My EE account on your phone's browser (not the app) or a computer. Once you're logged in, a chat window will pop up when an advisor is available.
If you can't get in contact with chat, please get in touch from an alternative phone.
Enjoy the rest of your trip 🙂
Lee
Re: Roaming
Can you turn my phone number on Roaming?
EE Employee
Re: Roaming
Hi @brasske
Here on the community, we do not have any account access please do follow my advice above to have this looked into.
Many thanks,
Lee
